How can I modify the line between columns?
janeverly
Post by janeverly » 2019-03-14 15:37:17
I want to modify the line between columns to make it narrower and gray instead of black. Is there a way to do this without using one of the drawing tools? Thanks.
Re: How can I modify the line between columns?
Post by adryan » 2019-03-16 00:46:45
G’day, janeverly et al
Help > Send Feedback… > Feedback Type: Feature Request :D
That is to say, I turned over all the rocks (including the Macro Language Reference) and could find nothing lurking underneath.
MacBook Pro (mid-2014)
macOS Mojave 10.14.6
Post by martin » 2019-04-09 13:04:13
It's true that you can't adjust the appearance of the section column divider line, no matter how many rocks you upturn. The default thin black line is the only available option.
Janeverly already contacted us about this privately, and we replied that we'll consider it as a possible future enhancement. Thanks!
