I have a book-length manuscript divided into several separate files. How do I add Part II to the end of Part I? I have done this before, but I can't remember how I did it.
Thanks in advance.
Simple Question: how to add a file to another
Frank Einstein
Re: Simple Question: how to add a file to another
There's a couple of ways for you to accomplish this:
1. If you need to join several documents together, you're probably best served by the menu Macro > Document > Join Files. It can stitch together multiple files from disk all at once.
2. You can drag a file icon into the text area of any open Nisus Writer document window. That will insert the contents of the dragged file wherever you drop it (ie: at the insertion point). You can drag these file icons from the Finder or other sources, eg: document proxy icons in window titlebars.
3. And of course there's good old copy-paste, though that's going to be the slowest method.
Frank Einstein
Thanks! I think I used method #2 in the past, but I didn't remember it today.
