Corrupted "Saved Expressions" for Search/Replace
ntx
Post by ntx »
Hi folks!
It looks my "saved expressions" data is partly corrupted. Everytime I try to edit or delete some of the entries, NWE crashes, while the others still work fine.
I know moving .plist file to the trash will fix the problem, but it will reset all my personal setting (incl. shortcuts) to the default... So I want to keep it as final choice.
Under such situations, is there any way to reset "saved expressions" in powerfind pane without deleting com.nisus.NisusWriter.plist from my library folder ?
Cheers
ntx
