Dear All:
I just started using Nisus after several years' break. Does anyone know how to place the footnote (and/or endnote) icons in the toolbar?
Thanks
						Footnotes
- scottwhitlock
There is no way to do this. I have found the toolbar to be totally useless in NWE and NWP, and attention and utility has moved over to the pallettes.
However, the footnote command is in the menu, and you can assign a shortcut of your choice to it (mine is Command-FN) which can consist of one or more letters and modifiers.
Scott
Scott
MacBook Pro 15
2.66 Ghz Core i7
8GB RAM
10.8.3
NWP 2.0.4
iPad 3
						2.66 Ghz Core i7
8GB RAM
10.8.3
NWP 2.0.4
iPad 3
