Section symbol problem
LongTermUser
Post by LongTermUser »
I am using the Section symbol § (option 6). When I reopen the document all of the section symbols are replaced by some generic graphic which prints as such.
How do I keep the section symbol from changing?
Thank you
Lorenz
Re: Section symbol problem
I just gave it a try and didn't have any problems. It may be related to the font you are using- what font do you have applied to the section symbol? Can you try applying Times to the section symbol and see if it still changes?
LongTermUser
I am using times font.
Hrm, well that is odd then. Can you send me a copy of the document using the menu Help > Send Feedback? Thanks.
