Maximum space between paragraphs
alexdennis
Post by alexdennis »
Sorry if this has been answered elsewhere.
I have a stylesheet with different levels of heading, each with space before and space after. H1 is 16 points after, H2 8 points before. If I generate a document with an H2 header immediately following a H1 header Nisus adds these together – so I get a 24 point space between paragraphs. In Word and (I believe) Pages the default for situations like this is the larger of the two, so there would be a 16 point space between (which is what I'm after). Is there a way of getting Nisus to default to this behaviour please? I can do this manually, or set up variant header styles for these circumstances, but then changing headings later on causes inconsistency.
No worries if this can't readily be done.
Thanks and best wishes
Alex
Re: Maximum space between paragraphs
Hello Alex,
I'm sorry but Nisus Writer does not have a feature to control how different paragraph styles' before and after spacing are combined. They are simply always applied in an additive way. You'll need to either adjust the spacing manually, or add customized styles for situations like this (eg: a new style "H2 after H1" that is based on "H2" but reduces the spacing as desired).
I'll file a feature request that we more easily allow the kind of combination you'd like, thanks!
G’day, Alex et al
Contextual formatting like this can indeed lead to headaches, especially in a long document with many headings. In such a case, I would not bother defining yet another style. Rather, when I had finished with the document, I would run a macro that adjusted the paragraph spacing around headings in the desired manner.
alexdennis
Thanks both – I'm not sure it's worth posting a feature request as I think this is probably a very marginal problem. I'll get cracking on setting up a macro, though, which is a fairly elegant solution.
All best wishes
Alex
