Nisus New File not working as default
Simeon
Post by Simeon »
Hello Martin (or anyone else),
I have just had a reinstall of all the apps on my computer, due to a botched system update. What resulted included certain problems with Nisus:
1. My dictionary additions were lost (but our IT man restored them)
2. My default new page is different from the Nisus New File.dot file —different font, different tabs, different font size. I even pulled in the old Nisus New File.dot from my backup, but this has not changed anything. The Nisus New File.dot is stored in the documents/Nisus Documents/templates/Nisus New File.dot, where the old one was.
Am I understanding incorrectly what determines what the default appearance of a newly opened blank file looks like?
Your help will be apprecaited
Brother Simeon
Light of the Spirit Monastery
ocoy.org
lightofthespiritpress.com
Re: Nisus New File not working as default
Hello Simeon! The problem is most likely that Nisus Writer is no longer loading the template file you expect and desire. Try this:
1. Open your preferences.
2. Switch to the "New File" pane.
3. Click the "Advanced" tab.
4. Underneath the heading "Template File: Nisus New File" make sure the file's location is as you expect.
If the targeted file isn't what you expect, click the "Choose" button to correct the problem. I hope that helps. Please let me know if you have any trouble.
Simeon
Post by Simeon »
This worked! Thank you, Martin.
Brother Simeon
ocoy.org
