Footnote style disappears each time I load a document
Bryand
Post by Bryand »
I'm working on a book with footnotes. I set the footnote style and work away merrily. The document is saved at the end of the day and the computer closed down. The following day the Footnote style has disappeared, although the pre-eisting footnotes conform to the format. I re-introduce the style and apply it to the day's work, but on the following day it has gone. This is now a daily experience.
There must be a reason for this. Any thoughts?
Re: Footnote style disappears each time I load a document
This sounds really strange Bryand, because footnotes intrinsically have the Footnotes style applied in Nisus Writer. Even if you open a non-Nisus file with footnotes lacking note styles, Nisus Writer would automatically create and apply a "Footnote" note styles. There might be a bug here or perhaps still just a misunderstanding.
The easiest way to diagnose this would be for us to see a sample document. Can you please send us a file that seems to lack the footnotes style? You can do so using the menu Help > Send Feedback or directly via:
Thanks for your help.
