Resize Window (newbie)
tedg
Post by tedg »
Would like to relocate and resize the frontmost document window. Tried the following and a few variations.
Is there a repository of example macros?
$doc.windowOrigin = 780;50
$doc.windowSize = 817;2111
Thanks in advance, Ted
User since 1990
Most current NWp and MacOS
MacBookPro 16-inch 2023
Re: Resize Window (newbie)
Try
$doc.windowOrigin = Size.new 780, 50
$doc.windowSize = Size.new 817, 2111
tedg
Post by tedg »
Philip,
Searched the forum and see how helpful you have been. Thank you on behalf of all of us.
But that did not fly. Terminate at the end of first line.
User since 1990
Hi Ted,
I guess I thought this was a bit of code you had ripped from a complete macro. :wink:
Of course for this code to work you will have to first define the variable $doc. So for example:
tedg
Post by tedg »
Thanks. I'll build from there and get back.
User since 1990
