InfoClick 1.2.8 released
Locked
This version is a maintenance update intended to restore M1 support and fix several issues.
This update is free for all existing users of InfoClick.
Get the Update:
If you purchased from Nisus Software directly (via nisus.com), you can update in several ways:
• Update from inside the app using the menu InfoClick > Check For Updates.
• Update by downloading the new version from our website.
If you purchased from Apple via the Mac App Store, the update is available through the App Store.
Changes
• Restored native support for Apple Silicon (M1).
• Fixed: possible crash when indexing malformed emails at higher indexing speeds.
• Changed: higher indexing speeds should use additional background resources.
• Fixed: skipping draft emails should update the progress bar.
• Fixed: don't let users close the progress window.
• Fixed: email counts in the progress window should be formatted using thousands separator
Locked
