Adjusting size of window upon launch
JRP
Post by JRP »
Is there any way to adjust the size of the window that Nisus launches for new files (other than manually adjusting it once the new file opens)? I'd like it to launch a larger window.
1. Open your Nisus Writer Express Preferences.
2. Switch to the New Document pane.
3. Click the Advanced tab.
4. Click the Edit File button.
5. Size the document window that appears to your liking.
6. Save and close the document.
From now on any new documents you create should use the window settings you made in step 5.
JRP
Post by JRP »
Perfect. Thanks.
