Finding embedded documents
ngazidja
Post by ngazidja »
In NWE it was possible to insert the body of one document into another. I did this quite enthusiastically for a while, but now find I have a document with others embedded but ca no longer find the originals. I'd like to find them or otherwise retreive them - they're currently visible in the master document, but I can't do anything with them - they're "framed" like images. How do I find them? Any suggestions?
Thanks!
As far as I know there is no way to embed RTF documents inside one another in NWX. When you drag a file icon to an NWX window the contents of the file are simply copied into the destination document. There is no linking/embedding. I hope that helps.
