Macro to Traspose Characters
lawrencegoodman
Post by lawrencegoodman »
I want to write a macro where it changes the order of two letters. So if the cursor is between the 't' and 'h' in the word 'the' and I trigger the macro, the word will change to 'hte'.
I have written the following macro:
$locationofcursor = selection location
Select Start
Set Selection $locationofcursor, 1
Cut
set selection location -1
Set Selection $locationofcursor , 1
Paste
Select End
I get an error because evidently you can't use negative numbers. So how do I move backwards one space? I am trying to do this without perl if I can so I can keep it simple and understand what I am doing.
Thanks for your help.
Re: Macro to Traspose Characters
lawrencegoodman wrote:I get an error because evidently you can't use negative numbers.
Correct, the Set Selection Location command takes an absolute character location/offset in the document. Thus if your document contains (N) characters then only (1) through (N + 1) are valid locations.
As macros currently do not have any commands that perform arithmetic you'll have to resort to Perl to calculate the character location you need. However, I think you'll find the code understandable:
Select Start
Cut
Begin Perl
     $locationofcursor = $locationofcursor - 1;
End
Set Selection $locationofcursor , 0
Paste
Select End
