saving multiple versions of a document
nlpaces
Post by nlpaces »
MS Word offers a routine for saving multiple versions of the same document via "snapshots". Does NWP offer anything similar?
Re: saving multiple versions of a document
nlpaces wrote:Does NWP offer anything similar?
You can use Kino's 'SaveWithDateTime' macro:
http://www2.odn.ne.jp/alt-quinon/files/NWPro/file/
If you use the macro often, you can assign a keyboard shortcut to it.
TommyW
Post by TommyW »
Oh how absolutely mega...
Thanks for pointing it out and thanks to the creator too. I've never looked at a macro before but it was clear enough and I could alter the formatting easily to match what I usually do.
That's great.
Candace
Post by Candace »
Is there a simple way for a non-technically proficient person to make this macro her own?
And while we're at it, how can I structure my replies in these forums so I can see the message to which I am replying?
Thanks. Candace[/quote]
shades
Post by shades »
Thanks. Candace
Howdy, Candace. If you look at the upper right corner of the message that you want to reply to there is a "Quote" button. Click it, and then you can add your reply. It will show the original message in a quote box when completed.
MBP 2.4 GHz, OS X 10.5.6
NWP 1.2, Mellel 2.6, iWork 08
Candace
Post by Candace »
Thanks. Candace
Got it! Thanks, Rich. Candace
dshan
Post by dshan »
Candace wrote:Is there a simple way for a non-technically proficient person to make this macro her own?
See this post in the NWP macros forum.
Candace
Post by Candace »
Thank you very much. C
