Would it be possible to have a toolbar icon for show/hide the navigator pane?
Also at the top of the navigator pane a small button "add bookmark as..". This would bring up the current add bookmark window with any highlighted text as the bookmark name, or you could add your own text.
To me at least, this would be a useful feature.
Feature Request
Feature Request
- scottwhitlock
- greenmorpher
In the meantime, for "show/hide" navigator, why don't you just set your own keyboard shortcut? Mine is command-option-n (I don't actually have the toolbar showing; I don't have much use for toolbars with simple, constantly used stuff in them which even I can remember the shortcuts for).
Same goes for "Add bookmark as ..." Make a variation on the Add Bookmark shortcut -- or if you want to sue As Bookmark As ... all the time, just take the shortcut off Add Bookmark and assign it to Add Bookmark As ...
Cheers, Geoff
Cheers, Geoff
Re: Feature Request
Why not a new voice in the gear menu at the bottom of the pane, like in Mail? Those two voices look as lonely as a couple of pips in a calabash.Tacitus wrote:Also at the top of the navigator pane a small button "add bookmark as..".
Groucho
- greenmorpher
Voices?
Cheers, Geoff
Cheers, Geoff
