EPS in a document shrunk
nuxisure
Post by nuxisure »
I downloaded NWP public beta 1.02 and opened my document with many diagrams in EPS. The document was created previously using NWP 1.0.1.
All the diagrams appear smaller than their boudingbox, i.e. 60-70% in area.
This is not a fatal problem as they all show up okay on printout.
When I work on the document and want to check the diagrams, since they are shrunk, hard to see.
The EPS files are all created with Illustrator.
Are you certain you are using the latest public beta (number 2)? What you're describing sounds exactly like a bug that was fixed.
If your version is correct, please submit a feedback report with the file by using the menu Help > Send Feedback. Thanks.
nuxisure
Post by nuxisure »
Never mind.
I downloaded the latest beta, and tried. The problem seems to be fixed!
Thanks,
