Keyboard shortcut doesn't save
Duncan
Post by Duncan »
Command + S does not save with 1.0.2 public beta 2 and Leopard.
Any help?
Do the small things first ~ Dewi Sant
What does happen? Do you see an error message? If you manually choose the menu File > Save do things work properly? It would help us if you sent in a feedback report with this information directly after the failure occurs by using the menu Help > Send Feedback.
