find a return
gemboy27
find a return
Post by gemboy27 »
I did a quick search, but couldn't find an answer
I used to be able to type cmd-return or shift-return in find, to look for find (mostly I did this to replace to returns with one), but the only way I can get a return into the find window is to copy and past
I can get line feed with cntrl-return...
what is the secret that I have forgotten or is this not available in pro
greenmorpher
Post by greenmorpher »
Hiya Gemmo
Just paste one in, or use the special characters in Powerfind or Powerfind Pro.
In PowerfindPro the return is shown as "\n".
Cheers, Geoff
gemboy27
Post by gemboy27 »
thanks
as a work around that works (roundly)
but is it not possible to insert a return with opt-return, as it was with NWE (pre-3)
I think this must be a mistake- you should be able to use Option + Return to insert a newline into the Find field (or Shift + Return for a soft return). I'll have us take a look, thanks.
gemboy27
just to clarify
Post by gemboy27 »
Martin,
Does everyone have this problem?
Does it reproduce n your machines...?
gemboy, it looks like this is a bug that affects all users.
gemboy27
Post by gemboy27 »
is this possible
the Gem found
a bug
Image whoo boy
