Add double cap option to QuickFix
kcheney
Post by kcheney »
The subject line says it all. Evidently I have a heavy finger on the shift key and it doesn't get off as quickly as it should. FOr example...
Unless you're really bored and want to enter in all possible words that you may double cap (eg: "FOr", "THe", "ALl", etc), this isn't possible. It is however filed as a feature request that we should add.
Groucho
Post by Groucho »
Here is a workaround.
Open Find/Replace.
Enable PowerFind Pro.
Uncheck Ignore Case.
In the Search box, type: \<A> Convert > To Capitalized.
But, mind, this changes uppercase words too (that is "CHAPTER FIRST" becomes "Chapter First"). If so, try to narrow the search by specifying the formatting.
Hope this helps. Henry.
Groucho
ssampler
Post by ssampler »
I posted two related macros to do this at:
http://www.nisus.com/forum/viewtopic.ph ... ight=#7826
Although I wrote them for NWX, they appear to work in NWP.
Groucho
Post by Groucho »
Oh my!
I didn't preview before posting, so html turned the text into a mess.
Below is the original:
Open Find/Replace.
In the Search box, type: \<[A-Z][A-Z]+
Click on Find All
Select Edit > Convert > To Capitalized.
Groucho
Groucho
Post by Groucho »
ssampler wrote:I posted two related macros to do this at:
I tried your macro. As it is, the code skips all-caps words, such as TOGETHER or FRONT, and any two-character word, like TO and IF.
It should be corrected as follows:
In line No. 9, substitute:
[a-z]*
for:
[a-z]+
I hope this will help for now.
Henry.
kcheney
Add double caps to QuickFix
Post by kcheney »
Thanks for the macros.
For me, though, much of the typing I do is so short it doesn't seem that running a macro on each and every item is something I am going to do.
Probably I should focus on improving my typing! I remembered the "correct double caps" option from some program's prefs and just thought I'd mention it; now it's in the list of potential future additions to NWP.
