feature request: 2 "display text" options in Cross
dpb
Post by dpb »
I write complicated reference books, and often use Cross-reference with large numbers of bookmarks. I often need to display both the "bookmarked text" and associated but variable number such as a page or item number - hundreds and potentially thousands of times in a single document.
At the moment, doing this involves quite a number of keystrokes and mouse actions for each item. It would be helpful if, once the Cross-reference dialog opens, two (or more) "display text" options could be selected simultaneously, perhaps as checkboxes, producing two variables at the same time rather than one for the same cross-referenced piece of text.
Thanks for taking the time to think about this. Also, please let me know if this is not the right place to be submitting feature requests.
- dpb
Thanks for the feature request, I'll file it.
You're welcome to post your requests to this forum if you think they would benefit from a discussion, or you'd simply like to have one. But probably the best channel to use is the menu Help > Send Feedback.
