Version
shob72
Version
Post by shob72 »
Nisus Writer customer service suggested that I upgrade to "version 3.0.2". I find that that is a Nisus Writer Express update, while in the Nisus Writer Pro version I use (1.0.3) the "Check for updates" button yields "Your version is current".
Buy that 3.0.2 upgrade or no?
Sebastian
NWP v 1.2.4
MacOS 10.7.5
I'm not sure I understand exactly. The current version of Express is 3.0.2, and the current version of Pro is 1.0.3. You should trust what the "Check for Updates" tells you.
However, if you already own Pro 1.0.3 it doesn't really matter what version of Express you have. The features/fixes in Pro always include those in Express. In other words, if you have the latest version of Pro, there's no reason to use Express.
shob72
to martin
Post by shob72 »
That answered it for me, thank you very much.
Sebastian
NWP v 1.2.4
MacOS 10.7.5
