shading behind text--how to remove
disfasia
Post by disfasia »
I am making a bibliography and sometimes to make it easier I cut and paste certain publication details from online sources (ie. Amazon)...But I get a coloured shading behind the text...like a box.
How do I remove this?
Thanks
Elbrecht
Re: shading behind text--how to remove
Post by Elbrecht »
Hi -
I would Paste Text Only - no need to remove then...
HE
MacBook Pro i9
Sequoia 15.7.4
NWP 3.4.1
You should be able to remove the coloring use the menu Format > Background Color > Remove Background Color Attribute.
