Page number with first page no number
disfasia
Post by disfasia » 2008-07-08 05:31:24
I have always used the page numbering format where the first page has no number. Now all of a sudden, this does not work. How can I get it to work?
Thanks.
Re: Page number with first page no number
Post by Hamid » 2008-07-08 09:40:11
In the sections palette in the Tooldrawer under Header/Footer, check ‘Different First Page’.
disfasia
Post by disfasia » 2008-07-09 00:42:00
Oh I did that...Like I said this has always worked before.. Now it no longer works. Why is this?
Thanks.
Post by martin » 2008-07-09 11:53:46
Do you have more than one section in your document? If so, make sure that the selection/caret rests in the first section of the document when you change the setting- the "first page" refers to the first page of the active section, not the whole document.
disfasia
Post by disfasia » 2008-07-14 08:08:33
No, I don't have sections (at least not that I know--how would I find out?). This always worked seamlessly before.
Post by Hamid » 2008-07-14 11:28:14
You can view section breaks by checking 'Show Invisibles' from the View menu; or you can use the following expression in the 'Find what' box of PowerFind Pro:
\u000c
disfasia
Post by disfasia » 2008-07-14 17:40:49
No there are no sections. What do I do now?
Thanks
Post by martin » 2008-07-15 18:04:58
Can you send us the file so we can have a look and see what the problem could be? Just use the menu Help > Send Feedback to and attach a copy of your document, thanks.
disfasia
Post by disfasia » 2008-07-18 07:08:18
Thanks. I will do this now!
Cheers.
