Nisus Writer Express Upgrade
Jean Le Tallec
Post by Jean Le Tallec » 2008-08-05 12:43:20
Hello Martin.
I upgraded Nisus Writer Express from 3.02 to 3.1, it worked fine but, It seems that I have lost the Thesaurus in the battle? Do you have any idea what I should do?
Thanks, Jean
Re: Nisus Writer Express Upgrade
Post by martin » 2008-08-05 13:45:42
Hi Jean,
Unless you deleted it yourself, the upgrade would not have removed Nisus Thesaurus. Is Nisus Thesaurus in your Applications folder? If not, you can always download the full version of Express and then copy thesaurus from that disk image to your Applications folder.
Jean Le Tallec
Post by Jean Le Tallec » 2008-08-05 20:05:26
Thank you, Martin, the old fellow must be a little shaky with his fingers…! I was able to download it (the thesaurus) as you suggested, and every is functioning well.
Sorry to have bothered you.
Thanks again.
Jean Le Tallec
Post by martin » 2008-08-05 22:50:51
No problem- glad to hear you got it working!
