Tables 1.5 with LinkBack feature
steintal
Post by steintal »
Now the new version of Tables (v 1.5) with LinkBack feature is available.
Hans Schäppi
Re: Tables 1.5 with LinkBack feature
steintal wrote:Now the new version of Tables (v 1.5) with LinkBack feature is available.
Hans Schäppi
So it is ... I've been using the betas since Daniel first released them and apart from a glitch in Beta 1, they have been absolutely stable for me. On the other hand, people, you must bear in mind that it is only a LinkBack client as yet ... i.e. you can post a graphic or whatever in from an application that works as a LinkBack server and be able to edit that in the original application ... but you can't yet paste a table from Tables — sorry about the wording — into NWP and be able to edit the data in that through Tables. Daniel told me he still hadn't worked out how to do that. So sometime ...
But if you want a good cocoa spreadsheet, unless you're using Numbers — and I find the cross between spreadsheet and page-layout confusing, to say the least — Tables is well worth looking into.
