Hi all,
I gather that it is no longer possible to "inverse selection" with a macro.
In a large (250 page) doc, I would like to select everything that is not in Lucida Grande. (This will include text in two or three different fonts.)
Is there a Find/Replace argument that will do this? I use PowerFind a lot, but have almost never used PowerFind Pro.
Thanks very much,
Brooke
Select everything not in a given font
Re: Select everything not in a given font
There is an invert selection macro in the macro repository. It sounds like you probably know how to select everything in Lucida using PowerFind, but let me know if you have any questions.
Hi Martin,
It worked like a charm! Yes, I searched for "Anything" in Lucida Grande, chose Find All, then inverted the selection.
Thanks very much!
Best,
Brooke
Thanks very much!
Best,
Brooke
