Nisus to PDF hyperlinks are lost
Usually when I save my Nisus docs as pdf my hyper links are not lost.
Now with this latest version, they are lost.
Can you help out?
Thanks.
Can you help out?
Thanks.
Re: Nisus to PDF hyperlinks are lost
I honestly don't think it possible that any version of Express/Pro ever saved hyperlinks out to PDF. Are you certain about this?
I read that having Adobe Professional makes this possible, but that does not seem to be the case either. Why are the links not saved?
Thanks for any help!
PDFs saved by Nisus Writer never have hyperlinks intact. It may be that you can use an Adobe product to add the links afterwards, or import an RTF file, but I don't know how that process works, sorry.
Not many applications can generate PDFs with hyperlinks using the PDF engine built into Mac OS X. Some exceptions I can think of right now are Pages and OmniGraffle. It would definitely be a nice feature to have in Nisus Writer Pro, so could you put this in the Feature Request database, please? Thanks!
Yes, I echo that request! Can you please put this on your next update. Hyperlinks for those of us in academia are becoming ever so important: more texts are available virtually and it is just easier to have hyperlinks for our students to click on from the syllabus to the actual reading or virtual work.
Thanks!
Thanks!
Hyperlinks in PDFs created by NWP rtf files are never lost for me when the PDFs are viewed in Adobe Acrobat.
When the same PDFs are viewed in Preview and some other PDF viewers, the links don't work.
I just downloaded NWP and tried it and NW Pro does not save the hyperlinks. In fact, I would say it is actually worse because what I ended up doing on my syllabus is adding the hyperlink as http://xxx... and so forth. When NWE saves as pdf this http writing works, but when NWP saves it as a pdf, it does not work.
Hi Hamid,Hamid wrote:Hyperlinks in PDFs created by NWP rtf files are never lost for me when the PDFs are viewed in Adobe Acrobat.
that's because Adobe have built a hyperlink detection mechanism into Adobe Reader. This mechanism will automatically "activate" hyperlinks, and it can be a very useful feature to have. As you have noticed, though, it is not available in other PDF readers, such as Preview. Also, keep in mind that Adobe Reader can't detect hyperlinks if they are masked, i.e. if you select some text and choose Insert>Hyperlinks>Add Link.
Again this does not explain how Nisus makes this happen. I have Adobe and the links from Nisus are NOT working in Adobe.
Just to clarify: I was speaking about masked Hyperlinks to which I presume Hamid was referring.
Hyperlinks in Nisus are dead when the file is saved as PDF.
A URL, even when pasted as plain text in NWP, is live when the PDF of the Nisus file is viewed in Adobe Acrobat. It is Acrobat which parses the URL and makes it behave as a hyperlink. A hyperlink display text which does not have the URL format won't be live in Acrobat.
Thanks for the clarification on this, I wasn't aware of that Adobe Reader feature.
And maintaining live hyperlinks, regardless of the display text, is filed away as something we'd like to add at some point.
Is there any progress on this (it appears to be still broken in the latest greatest version of NWP) -- this is a deal breaker for me finally getting away from FrameMaker.. :- /
Thanks.
Thanks.
Hi Martin,
Any news on the export of bookmarks/hyperlinks? I fear Nisus Writer has remained the only word processor that cannot do this. Please let me underline how important this feature is, in a world where documents are mostly delivered as PDF files.
Paolo
Paolo
