Spell checker quits checking
credneb
Post by credneb »
For reasons unknown and with no pattern I can discern, NWP stops checking spelling as I type, even though "Check Spelling as You Type" remains enabled as usual. The only indication that this has happened is that the red dots under misspelled works stop appearing.
NWP has not crashed, and everything else appears to be fine. If I manually call up the spell checker, it works as usual. It just doesn't do it ...as You Type. Quitting and restarting NWP gets ...as You Type working again.
I reckon this is not the expected behavior, which is the only reason I mention it.
Does this happen to others?
