Keyboard access in the Document Mananger
Thanks for that great new document manager. I find that this alone puts Nisus ahead of any other word processor I know. Using it often I have tried to find a possibility to enter the Filename or Document window directly from the keyboard. I have not yet found a way to do this. Closing and opening the DM window doesn’t help either. Is it maybe possible with the new Macro commands to get the cursor directly in either the Filename or the Document Content window?
Re: Keyboard access in the Document Mananger
I would have thought the normal methods (eg: tab key) would work, but it looks like the next/previous tab areas in the Document Manager window aren't very helpful. I'll file this as a bug. And I don't think any macro will help you, sorry.
