Inserting file
haver
Inserting file
Post by haver »
OK, here's the deal. I made many different files for different documents. I would like to be able to create a new document and then insert the files in this new document in a specific order so that if I change one of the files, the new document will also reflect the changes.
I haven't been able to do that with NWP. Anyone has a suggestion?
Thank you.
Re: Inserting file
NWP doesn't have any feature that does what you desire. However, Kino wrote a macro that will allow you to choose a set of files to combine together into a single document, separating each with a page break.
fsa
Re: Inserting file
Post by fsa »
Thanks so much! Kino's macro has been a lifesaver!
Vanceone
Re: Inserting file
Post by Vanceone »
Just as a note to Martin: LinkBack was designed for this, no? This is another case where allowing Nisus to be a LinkBack source as well as a receiver would be handy.
I miss Publish and Subscribe from System 7-9.
