I have a folder of Nisus docs (rtf), that I have been working on in 1.2, under Tiger, with no problems.
After the upgrade, when I try to save any of these documents, I get the following message:
Couldn't save document.
The document could not be saved because: The file
"Filename.rtf" could not be saved in folder "Folder".
I have to use Save As..., to replace the original file. Once I've done that, subsequent Saves are okay. Other files, in other folders, do not suffer from this, but I don't know how widespread the problem is.
Files are not locked, permissions are okay, Disk Utility finds no anomalies, but the Console says:
Nisus Writer Pro[26921] NSDocument called FSPathReplaceObject() and -39 was returned.
Nisus Writer Pro[26921] *** could not write to file because Error Domain=NSCocoaErrorDomain Code=512 UserInfo=0x187890f0 "The file “Filename.rtf” could not be saved in folder “Folder”." Are there any known workarounds for this? Thanks.
