I used "Compare Document macro" and encountered error as "
Perl reported an error:
2011-09-12 14:17:55.008 textutil[4253:613]
_CFServiceControllerBeginPBSLoadForLocalizations
timed out while taling to pbs
I ran the macro in NWP 2.0.1, MacBookPro macosx 10.6.8.
This is the first time I ran this macro in NWP 2.0.1, so I wonder this is 2.0.1 specific problem.
Is there anyone can solve this problem?
I hope to hear the solution, because this macro is very useful.
Kosaka
Compare Document macro error in NWP 2.0.1
Re: Compare Document macro error in NWP 2.0.1
Hrm, the error implies that there is some problem shuffling content between processes, perhaps something to do with the clipboard. It could be a transitory problem. I'd try restarting your Mac to see if that solves it. If the problem persists, could you please try:
1. Running the macro on a small document with no images (to see if the content size/length makes a difference).
2. Try using NWP 2.0 to see if the macro still works there.
Let me know how it goes, thanks.
Thank you Martin for your rapid reply and suggestion.
I tried to restart my computer and re-tried to run the macro.
The run was succeeded!
I'm sorry for my judge prematurely.
Next-time, I'll try either to restart my computer or to clear the clipboard and re-run a macro before to post in this forum.
Anyway, I appreciate you to help me.
Kosaka
Kosaka
No problem, I'm glad the problem cleared itself up!
