opening word documents
Hi, I've just downloaded the trial version of Nisus Writer Express 3.4 and it seems excellent except that I cant open word documents. All I get is a jumble of letters!
Re: opening word documents
It may be that there's something wrong with the file itself, or perhaps an issue with our importer. Could you send us one of these problematic Word documents? Thanks!
It happens with all our word documents but I'm attaching a couple of different ones. Thanks.
Nisus Test 2.doc
- (22.5 KiB) Downloaded 1796 times
Nisus Test 1.docx
- (17.74 KiB) Downloaded 1715 times
Thanks for posting the example files. However, I just tested in Express 3.4 and they open just fine (no gibberish, and with formatting intact).
Express 3.4 does rely upon OSX to import .doc/.docx files, so I wonder, what version of OSX are you using?
OSX 10.4.11
Also, I cant get the preferences to change to English UK. Is this because its just the trial version?
Thanks
Thanks
Ah, that's the cause of your troubles. As mentioned in the feature listing, Express requires OSX 10.5 or later to import .docx files. However .doc files should be imported on OSX 10.4, so that seens like a problem we'll have to look into.carouseldesign wrote:OSX 10.4.11
In the meantime, I might recommend Express version 3.3.2 which does not have this issue with .doc files (though it still won't open .docx files on OSX 10.4), or use Nisus Writer Pro which does not rely upon OSX for either .doc/.docx file import (and actually does a better job).
No, there are no limitations in the trial version. I'm not sure exactly what you mean when you say you can't get your preferences to English UK. Most likely you're confused as to how languages work in Nisus Writer.Also, I cant get the preferences to change to English UK. Is this because its just the trial version?
In Nisus Writer languages are like fonts, eg: you apply languages to text. Each bit of text in a document can have a different language applied. So there's no global language preference exactly (though you can set the default language for any new files you create). You'll probably want to read this FAQ entry:
http://nisus.com/forum/viewtopic.php?f=22&t=3337
Let me know if you have any questions.
