Doesn't Exist Error
dbuffington
Doesn't Exist Error
Post by dbuffington »
Hi Folks!
Since upgrading to Lion, I occasionally get this error message when trying to save a new, untitled document...
Any ideas?
Thanks!
Dave
Re: Doesn't Exist Error
What version of Nisus Writer are you using exactly?
It would be best to send in a feedback report (using the menu Help > Send Feedback) just after the problem occurs, which will capture version information and perhaps some additional information that helps diagnose the problem. Thanks!
dbuffington
martin wrote:What version of Nisus Writer are you using exactly?
I'm using 3.4.1, and I've just sent a feedback report. Thanks!
