Minor annoyance
bobmacatq
Minor annoyance
Post by bobmacatq »
I have a small bone to pick. In preferences I opt to have NPW open a template I created. When I open an existing doc, NWP opens the existing doc and a new doc from my template. When I turned off the 'open with' option, I have to select 'new' from the file menu. This is a minor annoyance right now. Is there a way around this that I'm missing?
Re: Minor annoyance
Yes, I've noticed this one and meant to post about it. Even more annoyingly, the new blank document opens in front of the existing one you open from the finder … that means you can't simply ignore it, you have to close it or move the document you want to edit in front of it. This, to the best of my recollection, has only been happening since 2.0.4.
Re: Minor annoyance
This is a bug, sorry for the annoyance. We'll look into getting it fixed, thanks.
bobmacatq
Re: Minor annoyance
Post by bobmacatq »
Martin!
Thank you - I guess I'm not daft, at least not for this reason.
Happy Point Loma Seafood!
Bob
Re: Minor annoyance
This should be fixed in version 2.0.5, which was just released.
