I wanted to load the "sentences" macros. However, my version if NWP has no Load Macro button on the Macro section nor do I have Library/Application Support/ Nisus Writer / Macros on the hard drive. What's wrong?
Fritz
load macro
Re: load macro
Hi Fritz, it sounds like you found our instructions on how to install a macro. Unfortunately those instructions appear to be a little out of date, as some of the menu command names have changed. I've just now updated the instructions, and the "Load Macro" command is now more descriptively called "Add Macro to Menu from File". Do you see that menu?
Let me know if that solves things for you, or if you still have any questions.
You probably do have such a folder, but OSX now hides the Library folder, so you wouldn't see it unless you took some special efforts in the Finder. The easiest way to get at it is to use the NWP menu Macro > Show Macros Folder in Finder.nor do I have Library/Application Support/ Nisus Writer / Macros on the hard drive
