Page breaks in tables
Steve Williams
Post by Steve Williams »
In MS Word, you can put a page break in a table to force the next row down onto the next page. I tried doing the same think in Nisus Writer Pro 2.07 but couldn't. Is there a way of creating the same effect. I couldn't find anything in the tables palette to control the placement of cells across pages.
Any thoughts. Thanks.
Re: Page breaks in tables
I'm afraid it isn't possible to insert a page break inside a table in Nisus Writer. I'll upvote the relevant feature request.
Probably the surest workaround is to split your content into two smaller tables and insert a page break between them in the regular body text.
Steve Williams
Okay. Thanks for the speedy reply Martin.
