After moving emails from inbox to elsewhere or archiving emails, do I need to rebuild the database?
Either I can choose "rebuild database" or "scan for new emails", can I rebuild the database of particular mailbox only?
Under what situation that I have to rebuild the database?
Thanks!
When do I need to rebuild the database
Re: When do I need to rebuild the database
Hello!
Generally, with normal usage, you should never need to rebuild the database. As long as you keep InfoClick running in the background, it will automatically scan for emails at regular intervals, keeping the database updated.
I hope that helps. Please let us know if anything is still unclear to you.
Any emails that are moved or archived will be detected by InfoClick automatically as it scans for new emails in the background.ephice wrote:After moving emails from inbox to elsewhere or archiving emails, do I need to rebuild the database?
Thanks a lot!
