Original macros?
KimTwemlow
Original macros?
Post by KimTwemlow »
This is embarrassing ...
Being a neat freak, I deleted the original macros that came with NWP on the grounds that I would "never need them". Well, guess what?!
I seem to recall there a few for fiddling with tables and I'm badly stuck on that front. Is there anywhere I can download them from again?
TIA
Restore default macros
1 Quit NWP if it is running.
2 Drag the 'Macros' folder out from your ~/Library/Application Support/Nisus Writer on to the Desktop.
3 Launch NWP.
A Marcos folder with the default macros will be recreated in the same location.
4 Move into this new Macros folder your own macros from the old Macros folder.
KimTwemlow
Thanks for replying Hamid. A new Macros folder was created OK - but it's empty.
In that case:
2 Drag the 'Nisus Writer' folder out from your ~/Library/Application Support on to the Desktop.
3 Launch NWP.
A new Nisus Writer folder with a Macros folder containing the default macros will be recreated in the same location.
4 Move into this new Nisus Writer folder resources from the corresponding locations of the old Nisus Writer folder.
I've placed a copy online of all the default macros in case anyone else wants them.
KimTwemlow
That did it! Thanks Hamid (and Martin). Much appreciated.
